Class 2 (2nd Engineer) MEKG 📅 Feb 2025
(a) How is the power to weight ratio of an engine sought to be increased by continuous development? (8)
(b) List the limiting factors, what is the typical power to weight ratio of a slow speed marine diesel engine of current generation? (8)
### (a) How the Power-to-Weight Ratio is Increased
The power-to-weight ratio, a key performance metric for marine engines, is increased by continuous development through two primary strategies: increasing the power output for a given engine weight, and decreasing the engine weight for a given power output.
**$$ \text{Power-to-Weight Ratio} = \frac{\text{Power Output (kW)}}{\text{Engine Mass (tonne)}} $$**
#### 1. Methods to Increase Power Output
