Class 1 (Chief Engineer) Engineering Management 📅 Jun 2025
Improvements in Rudder efficiency can considerably contribute in improving propulsion effectiveness. Discuss common rudder-efficiency improvement devices / techniques currently in use, referring to the following:-
(a) Rudder Thrust Fins
(b) Asymmetric Rudders
(c) Rudder Bulbs
(d) Grim Vane Wheels.
### Introduction to Propulsion Effectiveness
The overall propulsion effectiveness of a ship is a function of engine power, propeller efficiency, and hull interaction. A significant portion of energy is lost in the propeller slipstream, which is characterized by high axial velocity, rotational swirl, and a low-pressure hub vortex. The rudder, operating directly within this turbulent slipstream, can either contribute to further energy loss through drag or be designed to recover some of this lost energy. The devices discussed below are designed to modify the interaction between the propeller, its slipstream, and the rudder to improve hydrodynamic efficiency and reduce fuel consumption.
### (a) Rudder Thrust Fins
