Class 2 (2nd Engineer) MEP 📅 Feb 2026
It is found that the tie rods are persistently becoming slack. (a) State, with reasons, the possible causes. (5) (b) State, with reasons, the likely effects on the engine if it is allowed to operate with slack tie rods. (5) (c) Explain how this problem can be minimized? (5)
### Introduction to Tie Rods
Tie rods, also known as tie bolts, are long, heavy-duty steel rods that extend from the top of the cylinder block (entablature) down to the transverse girders of the bedplate in large, slow-speed two-stroke marine diesel engines. Their primary function is to hold the engine's main structural components—the bedplate, A-frame (or frame box), and cylinder block—together in compression. This ensures that the tensile stresses generated by the combustion forces are absorbed by the tie rods, placing the cast iron engine structure under a state of compressive pre-load and preventing it from experiencing damaging tensile loads.
**(a) Possible Causes for Persistent Slackening of Tie Rods**
Persistent slackening of tie rods is a serious condition indicating a progressive fault within the engine's structure or assembly. The possible causes are:
