Class 2 (2nd Engineer) MET 📅 Aug 2024
(a) List the factors that determine the starting torque of the three-phase induction motor. How does this torque generally compare with the value of the rated torque? (6)
(b) The low-voltage release of an a.c. motor-starter consists of a solenoid into which an iron plunger is drawn against a spring. The resistance of the solenoid is 35 ohm. When connected to a 220 V, 50 Hz, a.c. supply the current taken is at first 2 A, and when the plunger is drawn into the "full-in" position the current fails to 0.7 A. Calculate the inductance of the solenoid for both positions of the plunger, and the maximum value of flux-linkages in weber-turns for the "full-in" position of the plunger. (10)
(b) Given:
$Resistance \space of \space solenoid \space = \space 35Ω$
$Supply \space voltage \space = 220V, \space 50Hz$
