Class 2 (2nd Engineer) MET 📅 Feb 2026
(a) List the factors that determine the starting torque of the three-phase induction motor. How does this torque generally compare with the value of the rated torque? (6) (b) A three-phase induction motor is wound for four poles and is supplied from a 50 Hz system. Calculate: (10) (i) The synchronous speed. (ii) The speed of the rotor when the slip is 4 per cent. (iii) The rotor frequency when the speed of the rotor is 600 r/min.
### Part (a): Starting Torque of a Three-Phase Induction Motor
**(i) Factors Determining Starting Torque**
The starting torque of a three-phase induction motor is the torque produced by the motor at the instant of starting, i.e., when the rotor speed is zero and the slip is unity (s=1). The magnitude of this torque is determined by several key factors derived from the motor's fundamental torque equation:
$$ T \propto \frac{s E_2^2 R_2}{R_2^2 + (sX_2)^2} $$
