Class 2 (2nd Engineer) MEKG 📅 Sep 2022
Misalignment of the Main shafting between engine and propeller causes bearing overloads and shaft stress.
(a) State the difficulties associated with checking shaft alignment and the reasons why results are unreliable due to external factors.
(b) State the reasons for misalignment.
(c) Explain with a simple sketch how a bearing load is assessed.
(d) Explain how uneven loading could be rectified.
(e) Why wear down in main bearings is critical to the condition of the crankshaft and propeller shaft system
(a) Difficulties associated with checking shaft alignment:
Difficulties During Installation:
The ship's configuration changes when transitioning from being berthed to afloat, affecting alignment.
Natural deflection of the shafting occurs between supports due to its length and weight.
