Misalignment of the main shafting between engine and propeller causes bearing overloads and shaft stress:
(a) State the difficulties associated with checking shaft alignment and the reasons why results are unreliable due to external factors; (5)
(b) Explain with a simple sketch how a bearing load is assessed. (5)
(c) Explain how uneven loading could be rectified. (6)
