ETO ETO Exam papers 📅 Jan 2023
(a) On what factors does the capacitance of a parallel-plate capacitor depend? (6)
(b) A tuned circuit consisting of a coil having an inductance of 200µH and a resistance of 20Ω in parallel with a variable capacitor is connected in series with a resistor of 8000Ω across a 60 V supply having a frequency of 1 MHz. Calculate: (10)
(a) The value of C to give resonance.
(b) The dynamic impedance and the Q factor of the tuned circuit.
(c) The current in each branch
(a) The capacitance of a parallel-plate capacitor depends on three main factors:
Area of the plates (A):
A larger plate area results in a higher capacitance. This is because a larger area allows for more charge to be stored at a given voltage.
$$C\:\alpha\:A$$
