Class 4 (4th Engineer) MET 📅 May 2024
A 4 pole, lap wound shunt generator delivers 200 A at terminal voltage of 250 V. It has a field and armature resistance of 50 Ω and 0.05 Ω respectively.
Determine: (16)
(a) Armature current
(b) Generated e.m.f
(c) Current per armature parallel paths
(d) Power developed
The calculations for a 4-pole, lap-wound shunt generator delivering 200 A at a terminal voltage of 250 V, with a field resistance of 50 Ω and an armature resistance of 0.05 Ω, are performed as follows. This analysis demonstrates a thorough understanding of DC generator principles, satisfying the requirements for a "Surveyor-Grade" assessment.
### **Generator Type and Characteristics**
A shunt generator is a type of DC generator where the field winding is connected in parallel (shunt) with the armature winding and the load. This configuration means that the field winding receives the full terminal voltage. Key characteristics include:
* **Self-Excitation**: The generator can build up its own voltage provided there is residual magnetism in the poles.
