Class 4 (4th Engineer) MEP 📅 May 2024
A biological sewage system develops a fault, which necessitates opening the unit for repair.
(a) The risk associated with opening the unit.
(b) The precaution taken to reduce the risk.
(c) Explain the significance of biological oxygen demand (B.O.D.).
### (a) The Risk Associated with Opening the Unit
Opening a biological sewage treatment plant (STP) for repair is a high-risk operation due to a combination of atmospheric, biological, chemical, and physical hazards. A comprehensive understanding of these risks is critical before commencing any work.
1. **Atmospheric Hazards (Most Critical & Immediate Risk):** The anaerobic and aerobic decomposition of organic waste generates a hazardous atmosphere within the unit. This is the primary cause of fatalities in such operations.
* **Toxic Gases:**
