Class 4 (4th Engineer) MEP 📅 Jan 2024
A centrifugal pump has been opened up due to abnormal noise:
(a) List the checks you will carry out on various parts (4)
(b) Name the parts which may require replacement (4)
(c) Checks to be carried out after assembly (4)
(d) Operational parameters, which may be required to be compared with manufacturers test record. (4)
**(a) Checks to be carried out on various parts during overhaul:**
When a centrifugal pump is opened up, a systematic inspection of each component is crucial. The following checks would be performed:
* **Pump Casing (Volute/Casing Cover):**
* **Erosion and Corrosion:** Thoroughly inspect the internal surfaces, especially the volute tongue (cutwater) and discharge nozzle, for signs of erosion, corrosion, or cavitation pitting. Cavitation often manifests as a honeycomb-like texture.
