Class 4 (4th Engineer) MET 📅 Apr 2024
A wooden ring having a mean diameter of 200 mm and a cross-sectional area of 400mm is wound uniformly with a coil of 300 turns. If the current passed through the coil is 5A calculate the value of flux produced in the coil. (16)
### Objective
To calculate the total magnetic flux (Φ) produced in a coil wound uniformly around a wooden ring, given its dimensions, number of turns, and the current flowing through it.
### Underlying Principles
This problem involves the fundamental principles of electromagnetism in a toroidal core. The key concepts are:
