Class 4 (4th Engineer) MEP 📅 Oct 2022
An air cooler of a large two stroke marine diesel engine is showing poor performance. Suggest some measures you would initiate to rectify the problem and improve the performance. (16)
### Introduction and Purpose of the Air Cooler
The component referred to as an 'air cooler' on a large two-stroke marine diesel engine is more accurately termed the **Charge Air Cooler**. Its primary function is to cool the compressed air delivered by the turbocharger before it enters the scavenge air manifold. Cooling the charge air is critical for three main reasons:
1. **Increased Air Density**: According to Charles's Law, at constant pressure, the volume of a gas is proportional to its temperature. By cooling the air, its density ($$\rho = \frac{P}{RT}$$) increases significantly. This allows a greater mass of air (and therefore oxygen) to be delivered to the cylinders per cycle, enabling the combustion of more fuel and thus increasing the engine's power output (improved volumetric efficiency).
2. **Reduced Thermal Stress**: Lowering the scavenge air temperature reduces the peak cycle temperatures and the overall thermal load on critical components such as cylinder liners, piston crowns, and cylinder heads, thereby enhancing their service life and reliability.
