Class 4 (4th Engineer) MEKM 📅 Feb 2025
An auxiliary engine under load continuously fluctuates even with a steady load.
The fault you diagnose could be owing to
(a) The quality of fuel
(b) The quality of servicing of the governor in the last port
(c) The supply of charge air
(d) The overhaul of fuel injectors done in the last decarbonisation
Give a brief explanation as to why each of the above mentioned points either could be true or cannot at all be the reasons for such a fluctuation. (16)
### Analysis of Engine RPM Fluctuation
The continuous fluctuation of an auxiliary engine's speed under a steady load is a condition known as 'hunting'. This indicates a fault in the engine's speed control system or a variable input that mimics a change in load. Each potential cause must be evaluated based on its ability to create a cyclical, rhythmic variation in engine power output.
#### (a) The quality of fuel
