Class 4 (4th Engineer) MEP 📅 Mar 2026
A centrifugal pump has been opening up due to abnormal noise:
(a) List the checks you would carry out on the various components; (4)
(b) Name the parts which may require replacement; (4)
(c) Checks to be carried out after assembly; (4)
(d) Operational parameters, which may be required to be compared with manufacturers test record. (4)
### (a) Checks to be Carried Out on Various Components
Upon opening a centrifugal pump due to abnormal noise, a systematic and thorough inspection of all internal components is critical. The following checks should be meticulously performed:
1. **Bearings (Ball, Roller, or Sleeve):**
* **Visual Inspection:** Check for signs of spalling (flaking), pitting, brinelling (indentations), corrosion, and discoloration due to overheating.
