Class 4 (4th Engineer) MEP 📅 Apr 2025
An air cooler of a large two stroke marine diesel engine is showing poor performance. Suggest some measures you would initiate to rectify the problem and improve the performance. (16)
Addressing poor performance in an air cooler of a large two-stroke marine diesel engine is critical for maintaining optimal engine efficiency, preventing component damage, and ensuring compliance with emission regulations. A 'Surveyor-Grade' approach requires systematic investigation, targeted rectification, and meticulous verification.
### I. Symptoms of Poor Air Cooler Performance
Before initiating rectification, it is crucial to identify the key indicators of poor performance:
* **Elevated Scavenge Air Temperature (SAT)**: Higher than specified at engine load, often the primary indicator.
