An amplifier has an open-circuit voltage gain of 1000, an input resistance of 2000 Ω and an output resistance of 1.0 Ω. Determine the input signal voltage required to produce an output signal current of 0.5 A in a 4.0 Ω resistor connected across the output terminals. If the amplifier is then used with negative series voltage feedback so that one tenth of the output signal is fed-back to the input, determine the input signal voltage to supply the same output signal current. (16)
