Class 4 (4th Engineer) MEKM 📅 Jul 2025
An auxiliary engine under load continuously fluctuates even with a steady load. The fault you diagnose could be owing to: (16)
(a) the quality of fuel
(b) the quality of servicing of the governor in the last port
(c) the supply of charge air
(d) the overhaul of fuel injectors done in the last decarbonisation
Give a brief explanation as to why each of the above mentioned points either could be true or cannot at all be the reasons for such a fluctuation.
The problem describes an auxiliary engine whose speed continuously fluctuates (a condition known as 'hunting') despite operating under a steady load. This indicates a fault in the engine's speed control system or a highly inconsistent fuel supply. We will analyze the four potential causes.
### (a) The Quality of Fuel
**This is a plausible, but less common, reason for speed fluctuation.**
* **General Effect of Bad Fuel:** Typically, poor quality fuel (e.g., high water content, high cat-fines, low cetane number) results in a consistent, steady-state problem. This would manifest as a general loss of power, high exhaust temperatures, incomplete combustion, and smoke. The engine would likely stabilize at a lower power output, but it would not continuously hunt.
