Briefly explain the following:
(a) How would you know a Refrigeration system is 'undercharged'? (4)
(b) What should you do to ensure that there is no water leakage into the engine cylinder before starting main engine for sea? (4)
(c) What would be the probable cause of a rise in the level of the lub oil sump tank of a main engine? (4)
(d) How does the valve rotator as fitted on an exhaust valve of aux. engine work? (4)
