Class 4 (4th Engineer) MEKG 📅 Oct 2025
Compare the desirable qualities of the lubricating oil selected for each of the following duties and give reasons for the differing properties of the oils recommended for these three purposes:
(a) Auxiliary diesel engines;
(b) Stern tube bearings;
(c) Refrigeration compressors (16)
The selection of lubricating oil for marine machinery is a critical aspect of operational efficiency, reliability, and safety. Different machinery types present unique operating environments and challenges, necessitating lubricants with distinct sets of desirable qualities. A thorough understanding of these differences, including their chemical and physical limitations, is paramount for a Senior MEO Class 1 Examiner.
### (a) Auxiliary Diesel Engines
**Operating Environment and Challenges:**
Auxiliary diesel engines operate under demanding conditions characterized by high temperatures, significant mechanical stresses, and the presence of combustion byproducts. The oil must effectively lubricate, cool, clean, seal, and protect engine components from wear and corrosion.
