Class 4 (4th Engineer) SSEP 📅 Dec 2025
Considering that the engine room is the most common single space on board ships for fire to break out, discuss the merits and demerits of the following fixed fire fighting systems. (20)
(a) carbon dioxide
(b) pressure water spray
(c) high expansion foam
This answer evaluates the merits and demerits of Carbon Dioxide (CO2), Pressure Water Spray (Water Mist), and High Expansion Foam fixed fire fighting systems for a ship's engine room, as would be expected for a full-mark response in a Class 1 examination.
### (a) Carbon Dioxide (CO2) Total Flooding System
**Principle of Operation:** The primary fire-extinguishing mechanism of CO2 is **smothering**. By rapidly discharging a large volume of CO2 gas into a sealed space, it displaces the atmospheric oxygen, reducing the oxygen concentration from ~21% to below 15%, which is insufficient to sustain combustion for most materials. A secondary, minor effect is cooling, as the liquid CO2 expands into a gas (Joule-Thomson effect), but this is not its primary function.
#### Merits (Advantages):
