Class 4 (4th Engineer) MEP 📅 Nov 2024
Describe following procedures for rudder maintenance in a dry dock.
(a) What is Jumping Clearance and why is it considered a value of importance? (8)
(b) What is Rudder Drop and describe the procedure for measuring the rudder drop? (8)
### (a) Rudder Jumping Clearance
#### 1. Definition and Concept
Rudder Jumping Clearance is the vertical clearance provided between a stopper arrangement on the rudder blade and a corresponding stopper on the ship's stern frame or rudder horn. This clearance is designed to allow for a limited amount of upward movement of the rudder in heavy seas or during accidental grounding astern, without transmitting the shock load to the steering gear.
As cited in the reference material, pads are welded to the hull and rudder, and the clearance between these pads is the jumping clearance. Its primary function is to act as a mechanical stop.
