Class 4 (4th Engineer) MEP 📅 Sep 2024
Describe following terms used for pumps
(i) Flow Rate (2)
(ii) Cavitation (2)
(iii) Net Positive Suction Head (2)
(iv) Pressure (2)
(b) During watch keeping round what checks are required on running centrifugal pump? (8)
### (a) Description of Pump Terminology
#### (i) Flow Rate (Capacity)
* **Definition**: Flow rate, often referred to as capacity, is the volume of liquid that the pump moves through a system per unit of time. It quantifies the pump's output volume.
* **Factors**: The actual flow rate is determined by the pump's design (impeller diameter, speed) and the characteristics of the system it is operating in, specifically the total system head (resistance).
