Class 4 (4th Engineer) MEP 📅 Mar 2023
Describe safety guide lines to be followed for the usage of the following tools:
(a) General safety precautions for electric tools (6)
(b) Safety precautions with powered abrasive tools like grinding, cutting, wire buffing tools (6)
(c) Safety precautions using pneumatic powered tools (4)
### Safety Guidelines for Workshop Tools
This answer outlines the critical safety guidelines for the usage of electric, abrasive, and pneumatic tools in a marine engineering environment. Adherence to these protocols is mandatory to prevent personal injury and damage to equipment.
**(a) General Safety Precautions for Electric Tools (6 Points)**
1. **Pre-Use Inspection and Tool Condition:** Before any use, conduct a thorough visual inspection of the tool. Check for cracked casings, damaged power cords (chafing, cuts, exposed wires), and ensure safety guards are in place and functional. Defective tools must be immediately removed from service, tagged as 'DEFECTIVE - DO NOT USE', and reported for repair or replacement. Never use a tool that is not in perfect working order.
