Class 4 (4th Engineer) MEKM 📅 Jan 2023
Describe the effects upon the auxiliary engine of running with the following defects.
(a) Incorrect tappet (4)
(b) Carbon encrusted injector nozzle (4)
(c) Fouled turbo-charger (4)
(d) Worn out fuel pump cams (4)
Indicate how the defect may be detected and the rectifying action required in each case.
### (a) Incorrect Tappet Clearance
**1. Effects on Engine Performance:**
The effects depend on whether the clearance is too large or too small.
* **Too Small / Zero Clearance:**
