Class 4 (4th Engineer) MEKG 📅 Nov 2024
Describe the following metallurgical tests and explain why EACH is carried out:
(a) Impact test (4)
(b) Hardness test (4)
(c) Endurance test (4)
(d) Tensile test (4)
Metallurgical tests are crucial for evaluating material properties, ensuring components meet design specifications, predicting performance under various operating conditions, and for quality control. They are fundamental in marine engineering for material selection, failure analysis, and maintaining safety and reliability.
### (a) Impact Test
**Description:**
The Impact Test, commonly performed using either the Charpy V-notch or Izod method, measures a material's resistance to fracture under a sudden, high-rate loading. It involves striking a standardized notched specimen with a swinging pendulum from a fixed height. The energy absorbed by the specimen during fracture is then calculated from the height to which the pendulum swings after breaking the specimen. The notch in the specimen creates a stress concentration point, promoting brittle fracture and making the test sensitive to metallurgical characteristics.
