Class 4 (4th Engineer) MEKG 📅 Jun 2024
Describe the following metallurgical tests and explain why EACH is carried out:
(a) Impact test (4)
(b) Hardness test (4)
(c) Endurance test (4)
(d) Tensile test (4)
Metallurgical tests are crucial in marine engineering to ensure the integrity, safety, and reliability of components operating under diverse and often extreme conditions. These tests provide essential data for material selection, quality control, and failure analysis.
**(a) Impact Test**
* **Concept**: The impact test measures a material's resistance to fracture under a sudden, high-rate applied load, specifically its ability to absorb energy before fracture. This property is known as toughness.
* **Methodology**: The most common methods are the Charpy and Izod tests. A standardized specimen, typically with a V-notch or U-notch to localize stress, is supported at its ends (Charpy) or one end (Izod). A pendulum of known mass and swing height is released, striking the specimen in a precisely defined manner. The energy absorbed by the specimen during fracture is measured by the height to which the pendulum rises after breaking the specimen.
