Class 4 (4th Engineer) MEP 📅 Mar 2026
Describe the examination you will carry out on the following parts of an air compressor:
(a) Suction and delivery valves and seats (4)
(b) Relief valves and bursting discs (4)
(c) Coolers and cooling passages (4)
(d) Piston and piston rings (4)
A comprehensive examination of air compressor components is critical to ensure its safe, reliable, and efficient operation. The following surveyor-grade procedures outline the detailed inspection process for key parts, adhering to manufacturer's guidelines and good marine engineering practice.
### (a) Suction and Delivery Valves and Seats (4 Marks)
The examination of suction and delivery valves is critical as they directly influence the volumetric efficiency and overall performance of the compressor. The procedure is as follows:
1. **Dismantling and Identification**: Carefully remove the valve assemblies from the cylinder head. Mark each valve clearly to ensure it is returned to its original port, as mixing them can cause operational issues.
