Class 4 (4th Engineer) MEKM 📅 Apr 2024
Discuss the causes, possible associated hazards and lowering of thermal efficiency consequent on poor combustion in a Diesel engine cylinder. Illustrate your answer by means of indicator cards (16)
### **Poor Combustion in Marine Diesel Engines: Causes, Hazards, and Efficiency Impact**
Poor combustion is a critical operational issue in marine diesel engines, defined as the incomplete or inefficient burning of fuel within the cylinder. This failure to convert the chemical energy of the fuel into useful mechanical work results in reduced thermal efficiency, increased fuel consumption, and poses significant operational hazards.
#### **1. Causes of Poor Combustion**
Poor combustion can be attributed to deficiencies in the three essential elements of combustion: Fuel, Air, and Heat (Compression). These causes are categorized as follows:
