Class 4 (4th Engineer) MEP 📅 Nov 2024
Draw cooling water system of main engine and naming each component and describe flow of cooling water through the system. (16)
### **1. Principle and Types of Main Engine Cooling Systems**
The primary function of a main engine cooling system is to remove excess heat generated during combustion, ensuring that component temperatures are maintained within their design limits for optimal efficiency, reliability, and longevity. The system dissipates approximately 25-30% of the total heat energy released from the fuel. There are two principal system designs:
* **Direct Seawater Cooling:** An older design where seawater is directly used as the cooling medium for individual coolers (Lube Oil, Jacket Water, Piston Coolers, etc.). This system is simpler but suffers from corrosion, erosion, and fouling of engine components due to the aggressive nature of seawater. The system described in the reference material is an example of this type.
* **Central Cooling System (Indirect):** The modern standard on virtually all vessels. This system uses a centralized heat exchanger (Central Cooler) to transfer heat from a closed-loop freshwater system to seawater. The freshwater loop is further divided into a High Temperature (HT) circuit and a Low Temperature (LT) circuit. This design protects the engine components from seawater, allows for precise temperature control, and simplifies piping.
