Class 4 (4th Engineer) MEP 📅 Feb 2025
During recent periods of maneuvering, a number of air start valve bursting discs or cones have failed. In the circumstance, indicate how the actual cause might be:
(a) Detected; (8)
(b) Rectified. (8)
The failure of air start valve bursting discs or cones during maneuvering periods is a critical issue that necessitates thorough investigation and rectification to ensure reliable engine starting capabilities and safety. As a Senior MEO Class 1 Examiner, a comprehensive approach is required to detect and rectify the root cause.
### (a) Detection of the Actual Cause (8 Marks)
Detecting the actual cause of repeated air start valve bursting disc failures involves a systematic and detailed diagnostic process, combining operational data analysis with physical inspection and testing. The primary aim is to identify the underlying mechanical, pneumatic, or operational deficiencies leading to over-pressurization or premature failure.
1. **Initial Observations and Incident Documentation:**
