Class 4 (4th Engineer) MEP 📅 Sep 2024
During recent periods of maneuvering, a number of air start valve bursting discs or cones have failed. In the circumstance, indicate how the actual cause might be:
(a) Detected (8)
(b) Rectified (8)
The failure of air start valve bursting discs or cones indicates an issue within the starting air system, typically related to overpressure or the ingress of hot combustion gases. A "Surveyor-Grade" approach requires a thorough investigation to determine the root cause, rather than merely replacing the failed component.
### (a) Detection of the Actual Cause
Detecting the actual cause of air start valve bursting disc or cone failures involves a systematic approach, examining both the starting air supply system and the engine's air start valves and associated components.
#### 1. Initial Observations and System Status Review:
