Class 4 (4th Engineer) MEP 📅 Aug 2022
During your watch you observe that Main Engine L.O, sump level is rising due to contamination of lubricating oil. Describe the procedure to:
(a) Identify the contaminant. (6)
(b) Locate the cause of contamination (6)
(c) Action to make the oil suitable for its continued usage. (4)
### (a) Procedure to Identify the Contaminant (6 Marks)
A rising level in the Main Engine lubricating oil sump is a critical situation indicating contamination by a significant volume of another fluid, typically water or fuel oil. A systematic approach is required for positive identification.
**1. Initial Onboard Assessment & Sensory Checks:**
* **Visual Inspection:** Draw a representative sample from the sump sampling cock. Observe its appearance. A milky, opaque, or emulsified appearance is a strong indicator of water contamination. A noticeable decrease in viscosity (oil appears thinner) and a strong smell of diesel fuel indicate fuel contamination.
