Class 4 (4th Engineer) MEP 📅 Nov 2025
During recent periods of maneuvering, a number of air start valve bursting discs or cones have failed. In the circumstance, indicate how the actual cause might be:
(a) Detected; (8)
(b) Rectified. (8)
### Introduction
Air start valve bursting discs (or relief cones) are critical safety devices fitted to the air starting manifold of a large marine diesel engine. Their primary function is to protect the manifold from extreme overpressure. Such overpressure typically occurs when an air start valve fails to close (sticks open) after the starting sequence, allowing high-pressure, high-temperature combustion gases from the cylinder to blow back into the air start piping. Repeated failures of these discs are a serious safety concern, indicating a significant risk of an air start line explosion and pointing towards a persistent underlying fault in the system that must be methodically detected and rectified.
### (a) Detection of the Cause (8 Marks)
A systematic investigation is required to accurately diagnose the root cause of repeated bursting disc failures. The process should proceed from the component level to the system level.
