Class 4 (4th Engineer) MEKM 📅 May 2024
Efficient smooth combustion depends upon some or all of the following: (16)
(a) A sufficiently high temperature to effect ignition
(b) A large delay period or ignition lag
(c) A minimum of after burning
(d) A large and rapid rate of pressure rise during the second stage of combustion
(e) Rapid heat losses to the walls
Give the correct answer with adequate justification
The correct statements for efficient and smooth combustion are (a) and (c).
### Detailed Justification
**(a) A sufficiently high temperature to effect ignition**
**Verdict: CORRECT**
