Class 1 (Chief Engineer) Engineering Management 📅 Jun 2024
Periodical Lub oil analysis, its correct interpretation and corrective measures are of critical significance for the maintenance of marine machineries. With reference to the modern analysis techniques employed for the condition analysis of LO, discuss the following: (16)
(a) Elemental (Spectrometric) Analysis
(b) Fourier Transform Infrared (FTIR) Spectroscopy
(c) Particle Count
(d) Base Number Vs Acid Number
Lubricating oil is the lifeblood of marine machinery. Its periodic analysis is a cornerstone of a predictive and preventative maintenance strategy. Correct interpretation of analysis results allows engineers to identify incipient faults, prevent catastrophic failures, and optimize lubricant consumption. The following modern techniques provide a comprehensive assessment of the oil's condition and the machinery it lubricates.
### (a) Elemental (Spectrometric) Analysis
**1. Principle:**
Elemental analysis, also known as spectrometric analysis, quantifies the concentration of specific metallic elements dissolved or suspended as fine particles within an oil sample. As machinery components wear, they release microscopic metallic particles into the lubricant. The type and concentration of these elements provide a direct indication of the location and severity of wear. The primary techniques used are Inductively Coupled Plasma (ICP) or Atomic Absorption Spectroscopy (AAS), which are capable of detecting elements at parts-per-million (ppm) levels.
