Class 4 (4th Engineer) MEKM 📅 Feb 2024
Explain how leakage of the undermentioned valves may become apparent to watchkeepers and state the effects on engine operation. Describe the immediate and subsequent action which might be necessary in each case.
(a) Exhaust valve
(b) Fuel valve
(c) Air Starting valve
### (a) Exhaust Valve Leakage
#### Apparent Indications to Watchkeepers
1. **High Exhaust Temperature:** The primary and most immediate indication is a steady rise in the exhaust gas temperature of the specific, affected unit, observable on the engine control room's pyrometer panel or monitoring system. This deviation from the average temperature of other cylinders is a key diagnostic sign.
2. **Loss of Power:** The engine's overall RPM may drop, or the fuel rack position will need to increase to maintain the same speed, indicating a loss of power contribution from one cylinder.
