Class 4 (4th Engineer) MEKM 📅 Aug 2023
Explain how the following conditions affect the power developed by a diesel engine
(a) Broken piston rings (4)
(b) Worn fuel pump plungers (4)
(c) Fouled turbochargers (4)
(d) Worn out liner (4)
The power developed by a diesel engine is a direct function of the Mean Indicated Pressure (MIP) generated within the cylinder during the combustion process. The MIP is the average pressure exerted on the piston throughout one complete engine cycle. Any condition that negatively impacts the efficiency of combustion or the engine's ability to utilize the energy released will result in a lower MIP and consequently, a reduction in developed power. The formula for indicated power illustrates this relationship: $$ P_{indicated} = \frac{(P_{mean} \times L \times A \times N \times n)}{k} $$ where a reduction in $$ P_{mean} $$ directly reduces power.
### (a) Broken Piston Rings
Broken piston rings primarily cause a loss of power by compromising the gas-tight seal between the piston and the cylinder liner.
* **Loss of Compression:** During the compression stroke, the broken rings fail to contain the cylinder charge. A significant portion of the air leaks past the piston into the under-piston space or crankcase. This phenomenon is known as 'blow-by'.
