Class 4 (4th Engineer) MEP 📅 Feb 2024
Explain in detail how you would isolate one section of a water sprinkler system for routine maintenance. Describe all tests and inspections you would make and how you would return the system to service. (16)
A comprehensive procedure for isolating, maintaining, and restoring a water sprinkler system as per SOLAS requirements involves a systematic approach focusing on safety, system integrity, and regulatory compliance. The following steps detail the process to achieve full marks.
### Part A: Isolation of a Sprinkler Section
Proper isolation is critical to ensure the safety of personnel and prevent accidental discharge. A Permit-to-Work (PTW) system must be followed.
1. **Communication and Authorization**:
