Class 4 (4th Engineer) MEKM 📅 Apr 2024
Explain the advantages of fitting highly rated medium speed engines with double exhaust and air intlet valves (6)
(b) State the disadvantages of double valve arrangements (4)
(c) Explain the possible causes of persistent burning of exhaust valves if it is:
(i) General to most cylinders (3)
(ii) Specific to a single cylinder (3)
### (a) Advantages of Double Inlet and Exhaust Valves (4-Valve Arrangement)
The use of a four-valve (two inlet, two exhaust) configuration in highly rated medium-speed engines offers significant performance advantages over a traditional two-valve design. These benefits are crucial for achieving higher power density and efficiency.
1. **Enhanced Volumetric Efficiency (Improved Breathing):** The primary advantage is a significant increase in the available flow area for intake air and exhaust gases. While one large valve occupies an area proportional to its diameter squared ($$\pi r^2$$), its flow area is proportional to its circumference ($$2 \pi r$$). Two smaller valves can be fitted into a similar space, but their combined circumferential flow area is substantially greater than that of the single larger valve. This allows for a larger mass of air to be inducted during the intake stroke and reduces resistance (pumping losses) during the exhaust stroke, leading to better scavenging and cylinder charging.
2. **Capability for Higher Engine Speeds (RPM):** Individual valves in a four-valve setup are smaller and have significantly less mass and inertia than a single large valve. This reduction in reciprocating mass allows for higher valve acceleration and deceleration rates without the risk of 'valve float' (where the spring cannot keep the follower in contact with the cam). Consequently, the engine can be designed to operate safely at higher rotational speeds, directly increasing its specific power output.
