Class 4 (4th Engineer) MEKG 📅 May 2024
Explain the following terms and give examples of where each condition might occur:
(a) Stress Corrosion cracking (6)
(b) Creep cracking (5)
(c) Corrosion fatigue (5)
The following material degradation phenomena are critical considerations in marine engineering, particularly in ensuring the integrity and longevity of shipboard components:
**(a) Stress Corrosion Cracking (SCC)**
Stress Corrosion Cracking (SCC) is a insidious form of material degradation characterized by the brittle fracture of an otherwise ductile material, occurring due to the synergistic action of a susceptible material, a specific corrosive environment, and sustained tensile stress. This phenomenon often leads to sudden and unexpected failures without significant prior deformation, making it particularly dangerous.
* **Concept**: SCC is not simply corrosion or mechanical failure but a combined effect. Neither the stress nor the corrosive environment alone would typically cause the rapid failure observed when both are present.
