Explain the term incinerator and the function of incineration on board ships in order to prevent / minimise contamination of marine environment. Draw a typical process flow diagram of incineration. How is incinerator ash disposed off. (16)
### 1. Definition of a Shipboard Incinerator
A shipboard incinerator is a furnace or a combustion device designed for the high-temperature burning of solid and/or liquid waste generated on board a vessel. Its primary purpose is to reduce the volume of waste, sterilize it, and convert it into a more manageable, inert residue (ash) and flue gas. The process is governed by stringent international regulations, primarily MARPOL Annex VI, to ensure that the combustion process itself does not cause undue air pollution.
### 2. Function in Preventing Marine Contamination
The primary function of incineration is to serve as a critical component of a ship's integrated Waste Management Plan, thereby minimizing contamination of the marine environment. This is achieved through several key mechanisms:
