Class 4 (4th Engineer) MEP 📅 May 2024
Explain with a suitable diagram, the components of a an auxiliary engine fuel valve? Briefly explain, the process of overhauling and pressure testing the fuel valve? (16)
A fuel valve, also commonly referred to as a fuel injector or fuel nozzle, is a critical component in a diesel engine's fuel injection system. Its primary function is to atomize fuel into a fine spray pattern and deliver it into the combustion chamber at the correct timing and pressure, ensuring efficient and complete combustion.
### I. Fuel Valve Components
A typical auxiliary engine fuel valve consists of the following main components, designed for high-pressure fuel delivery and precise atomization:
* **Nozzle Body (or Nozzle Holder)**: This is the main housing of the fuel valve assembly. It's typically made of hardened steel to withstand high pressures and temperatures. It provides mounting for the nozzle and houses the spring mechanism.
