Explain with a suitable diagram, the components of a an auxiliary engine fuel valve? Briefly explain, the process of overhauling and pressure testing the fuel valve? (16)
The fuel valve is a critical component in the combustion process of an auxiliary engine, responsible for injecting and atomizing fuel into the combustion chamber at the precise moment and in a suitable form for efficient combustion.
### A. Components of an Auxiliary Engine Fuel Valve
A typical auxiliary engine fuel valve is a spring-loaded, hydraulically operated needle valve designed for high-pressure operation. Its primary function is to deliver a finely atomized spray of fuel into the cylinder at the correct injection timing and pressure. The main components include:
* **Valve Body/Casing:**
