Class 4 (4th Engineer) MEP 📅 Aug 2024
Explain with a suitable diagram, the components of an auxiliary engine fuel valve? Briefly explain the process of overhauling and pressure testing the fuel valve? (16)
### **Function of an Auxiliary Engine Fuel Valve (Injector)**
The primary function of a fuel injector in a marine auxiliary diesel engine is to deliver a precisely metered quantity of fuel into the combustion chamber. This must be accomplished at a very high pressure, at the correct moment in the engine cycle, and in a finely atomized state to ensure efficient mixing with air, complete combustion, and maximum power output.
### **Components of a Fuel Valve**
Based on a typical design, the main components of a fuel valve are as follows:
