Class 4 (4th Engineer) MEP 📅 Jul 2025
Explain in detail how you would isolate one section of a water sprinkler system for routine maintenance. Describe all tests and inspections you would make and how you would return the system to service. (16)
### **Introduction and Governing Principles**
The automatic water sprinkler system, as mandated by SOLAS Chapter II-2, Regulation 10, is a fixed fire detection and extinguishing system designed to automatically detect a fire, transmit an alarm, and immediately commence suppression. Routine maintenance is critical to ensure its reliability and is governed by the FSS Code and the vessel's Planned Maintenance System (PMS). This procedure details the systematic isolation, maintenance, and restoration of a single section, ensuring the integrity of the remaining system and the safety of the vessel.
### **Part 1: Procedure for Isolating a Section**
A systematic and safety-conscious approach is paramount. The following steps must be executed in sequence:
