Class 4 (4th Engineer) MEKM 📅 Nov 2023
For 2-Stroke Marine Diesel Engine;
(a) Describe problems in achieving good lubrication of Cylinder Liner. (6)
(b) What are the properties of good cylinder oil? (4)
(c) What are the consequences of UNDER & OVER lubrication of liner? (6)
### (a) Problems in Achieving Good Lubrication of Cylinder Liner (6 Marks)
Achieving an effective and consistent lubricating oil film on the cylinder liner of a large 2-stroke marine diesel engine is fraught with challenges due to the extreme operating environment and mechanical design constraints. The primary problems are as follows:
1. **Extreme Operating Conditions**:
* **High Temperatures**: The upper part of the liner is exposed to combustion temperatures exceeding 1500°C, while liner surface temperatures can reach 250-300°C. This extreme heat can cause thermal breakdown (cracking) and oxidation of the lubricating oil, reducing its effectiveness and leading to the formation of carbonaceous deposits.
