If a radial piston hydraulic pump fails to deliver rated fluid volume, the cause can be _________. (16)
(a) Contaminated fluid
(b) Pitted thrust rings
(c) Worn pintle bearings
(d) Obstructed suctions passage
Briefly, justify your answer.
### Correct Answer
(d) Obstructed suction passage
### Justification for Full Marks (16/16)
As a Senior MEO Class 1 Examiner, a complete answer requires not only identifying the correct option but also providing a detailed analysis of the underlying principles and a comparative evaluation of all given options. The failure to deliver rated fluid volume is a direct symptom of reduced volumetric efficiency.
