Class 4 (4th Engineer) MEKM 📅 Aug 2025
If an auxiliary diesel generator over speeds while off load, explain:
(a) How can the engine be stopped? (6)
(b) What are the probable reasons for the failure? (4)
(c) Give details of the checks that are required to be made after the engine has been stopped, with regard to (6)
(i) Mechanical checks and,
(ii) Electrical checks
### (a) Procedure to Stop an Overspeeding Auxiliary Engine (6 Marks)
Upon detection of an overspeed condition where the primary automatic overspeed trip has failed to actuate, the following sequential actions must be taken to stop the engine, prioritizing the safest methods first.
1. **Remote Emergency Stop:**
* The first and safest action is to attempt to stop the engine remotely from the Engine Control Room (ECR) or the local control panel using the emergency stop button. This action typically de-energizes a fuel solenoid valve, cutting off the fuel supply to the engine instantly and safely.
