Class 4 (4th Engineer) MEP 📅 Jul 2022
It is planned to carry top overhaul of auxiliary engines; spell out procedure on removal of cylinder cover and overhaul of safety valve/indicator valve assembly, naming the parts with a simple sketch. (16)
### **Top Overhaul of Auxiliary Engine: Cylinder Cover and Valve Assembly**
A comprehensive procedure for the top overhaul of an auxiliary engine, specifically addressing the removal of the cylinder cover (head) and the overhaul of the combined safety/indicator valve assembly, requires meticulous planning, adherence to safety protocols, and systematic execution as detailed below.
#### **1. Safety Precautions and Preparatory Work**
Prior to commencing any work, the following safety measures are mandatory:
